I got a notification from Windows Defender to clear processor something antvirus this and that and because of these meltdown things that were happening I agreed and have to restart the Pc. As I am at my gparents house I only brought the PC, HDMI, mouse and a controller to play with. Now it says press F3 to clear TPM
F4 to skip
I have no keyboard and I cant bypass this tried rebooting, CMOS reset and it wont go away, any solutions, ways to bypass , use android as a keyboard? I cant wait to go home and then use the PC ?
Edited by galaxyrooter
Added media
https://linustechtips.com/topic/933507-bypass-tpm-clear/
F4 to skip
If you have android, there are a number of apps that let you use an onscreen keyboard:
https://play.google.com/store/apps/details?id=remote.hid.keyboard.client
https://code.google.com/archive/p/androhid/
Most require root though, YMMV.
Edited by ionbasa
▶ Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning. - Einstein◀
Please remember to mark a thread as solved if your issue has been fixed, it helps other who may stumble across the thread at a later point in time.
https://linustechtips.com/topic/933507-bypass-tpm-clear/#findComment-11404225
This requires modding kernel which I am not familiar with at all. I can install a custom kernel but no one made it for S6 edge. So I am outta luck there. I have to bypass ?
https://linustechtips.com/topic/933507-bypass-tpm-clear/#findComment-11404232
I'm not entirely familiar with rooting, so you may be out of luck with that app in particular.
Maybe try searching around or wait for another forum member to give their recommendation.
https://linustechtips.com/topic/933507-bypass-tpm-clear/#findComment-11404236
