well i have an 8 gb Kingston hyper x fury black stick(2133mhz) and i am planning to get an g skill aegis ram also clocked at 2133 MHz  so will it work ?
mobo- gigabyte h110m-ds2
cpu- Intel core i3 6100
well i cant find any of the kingstone ram of that frequency here so my only choice is g skill.. and yes they only have 4 gig stick . so will also get a gtx 1050ti or gtx 1050 with it as my old gtx 970 is dead now
hoping for a reply soon
here are the links
https://mdcomputers.in/g-skill-aegis-ddr4-f4-2133c15s-4gis.html
https://www.amazon.in/HyperX-2133MHz-Non-ECC-Desktop-HX421C14FB/dp/B00TY6A56U/ref=sr_1_2?ie=UTF8&qid=1527846441&sr=8-2&keywords=kingston+8gb+ram+ddr4+2133mhz
https://linustechtips.com/topic/933033-help-with-ram-selection/
4 minutes ago, Eat_Ramen said:
i mean i have heard people say things about ram timing and stuff and i have zero ideas with that topic
if there are ram sticks with different speeds they will all run at the lowest speed. eg if you have a 1600mhz ram and a 2400mhz ram they both will run at 1600mhz
https://linustechtips.com/topic/933033-help-with-ram-selection/#findComment-11399824
