@Bradlevesque
Sorry to be "that guy", but can you convert that into a gif or host it on a streaming platform somewhere? A lot of the people who might be able to help you with a problem are not necessarily going to take the risk of downloading an attachment from a brand new poster, even though they might want to help.
https://linustechtips.com/topic/932899-please-help-me/#findComment-11398604
10 minutes ago, Tabs said:
@Bradlevesque
It's a rather long and large file for a gif, not sure if this site supports a gif this large but let's see if it embeds anyway. Spoiler due to flashing images.
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
https://linustechtips.com/topic/932899-please-help-me/#findComment-11398617
  Reveal hidden contents
Thank you good sir!
@Bradlevesque, Have you tried using a different cable? It looks like the monitor is struggling to receive a coherent signal, but the way in which it flickers would imply a hardware problem of some kind rather than software.
The easiest things to check are your cables, so try using a different one first. If the same thing happens, try connecting the monitor to a different source, like a games console.
Let us know if you're able to try those (and the results) and it'll help us narrow down where the problem is.
https://linustechtips.com/topic/932899-please-help-me/#findComment-11398627
14 hours ago, Tabs said:
Thank you good sir!
I will try that, thanks
https://linustechtips.com/topic/932899-please-help-me/#findComment-11400135
