Hi guys,
Im looking to get a case for my build. Id like it to be a full tower so there is plenty of room and good air flow, glass side panel, and enough room for a 360 Radiator with 3x120 fans on either the front or the top, but i also want to put 3 fans on the top or front (where ever the radiator isnt).
Thanks.
https://linustechtips.com/topic/932354-case-help-please/
I think you're mistaken on what a full tower is. They're gigantic. Like... gigantic. Look at the Corsair 1000D or the Phanteks one (don't remember the name) I have a Phanteks Enthoo Pro M TG which has support for 360 rads at the top and front, pump mounts and everything. It's really good especially considering you can get it for ~90$.
https://linustechtips.com/topic/932354-case-help-please/#findComment-11393552
10 minutes ago, Oral Fuat said:
Hi guys,
Thanks.
I think you mean Midi tower...
Full towers are massive, I wouldn't recommend one unless you have a reason
https://linustechtips.com/topic/932354-case-help-please/#findComment-11393562
