Hi,
I rebuild my old desktop with the following specs:
Asus rampage iv extreme motherboard
Asus Geforce GTX 680
Corsair Ax1200i PSU
Corsair AIO liquid cooler
Corsair Dominator platinum DDR3 1866MHz Ram 32gigabyte(4 times 8)
Intel core i7-3930K @g.20GHz
The goal was to clean out the everything because there was dust build up from about 2 ears or so. so took the gpu out and the fans(of the case and AIO) and cleaned them with compressed air and a lint free rag. after cleaning them I cleaned the case's filters and the general case itself. after that I took a small compressor and blew off the motherboard and case free of the dust left over. note that I didn't take the cooler or radiator of the cpu but what I did do is lay to radiator in the case under the cpu(air may be gone into the block???) now I reinstalled everything but now the system doesn't boot properly. sometimes in makes it to the desktop but other times it doesn't get past the boot. ive tried to run 2 stick of ram instead of 4 and also 1 stick. but still the same thing. I don't really know where to look for. I think the psu is fine. ive tried to reset the cmos(via the button on the rear) and reset to optimized defaults when I did get into the overclock menu. but both did nothing to.... Any tips?
Edit: I did get to starting windows(its running windows 7) and then it shut off again... still no clue
best regards and thank in advance
Pim
https://linustechtips.com/topic/932302-issues-after-rebuild/
Did you clean out your PSU? Because dust or hair can mess with the electrical conductivity. Does it boot into the BIOS Properly? If it does make sure the motherboard can detect everything. And Turn off the system and go through the wiring again make sure everything's plugged in properly.
https://linustechtips.com/topic/932302-issues-after-rebuild/#findComment-11393116
4 minutes ago, Pieming said:
Okay so i look in the monitor tab of advanced mode an i am seeing that cpu temparature is at 80 degrees.... which i dont think seems right? For only starting up and going to this tab?
Are you sure that your fan is plugged in cpu_fan?
https://linustechtips.com/topic/932302-issues-after-rebuild/#findComment-11393195
Your CPU AIO is not warking ! idle CPU temps with working AIO should be aro 25 -35 deg C and not 80 !
What AIO Corsair model do you have ??
CPU: i7 7700k @4.5GHz (5.0Ghz @ 1.35V - delidded)  Motherboard: Asus MAXIMUS IX CODE RAM: CORSAIR VENGEANCE LED Series DDR4 4 x 8 GB @ 3200MHz GPU: ASUS GTX STRIX 1080 Ti OC Case: Corsair X460 SSD: 2 x Samsung 860 EVO 250GB M.2 SATA SSD  PSU: Corsair Corsair 750 Watt RMx RM750X Monitor: ASUS 27" ROG Swift PG278QR Quad HD G-SYNC Keyboard: Corsair STRAFE RGB MX Silent Mechanical
https://linustechtips.com/topic/932302-issues-after-rebuild/#findComment-11393240
I am not an expert but in my opinion you shouldn't hear a water movement in the AIO when shaking ... at least I cannot hear it in main (corsair h100i v2).
I would say, unless your AIO pump is not working you have an air-lock in the pump and therefore high temp of the processor. Unfortunately this type of AIO are not repairable.
EDIT:
Try to log to the Windows and straight away go to CORSAIR LINK and make sure pump is running ... good luck.
https://linustechtips.com/topic/932302-issues-after-rebuild/#findComment-11393304
Ok so after some research I have found out that your AIO isn't connected to CPU_FAN Header but CPU_OPT which is fine but maybe it is worth to check ??
EDIT:
CPU_FAN Header is located slightly to the left
https://linustechtips.com/topic/932302-issues-after-rebuild/#findComment-11393339
No problem my pleasure, try to switch them over as If CPU_FAN header detects the fan is not running or not running properly, it will shut down your system (or refused to start your system) to protect your CPU from overheating.
https://linustechtips.com/topic/932302-issues-after-rebuild/#findComment-11393413
