Hi guys,
I've bought the MSI B350M Mortar and Ryzen 5 2600. Is there a better way to cool down the VRM?
Tried to overclock the CPU to 4.2ghz and saw 90c-100c on system in HWInfo64 while stress test using Prime95 for 5 minutes. That got me scared a little and I ended the best before it goes beyond 100c.
Will it be okay if i stick some of these ( https://www.sparkfun.com/products/11510 ) on top of the VRM heatsink without removing the actual heatsink?
I would like to avoid using a 30mm fans and float it above the VRM as it's not that aesthetically pleasing.
Is it a viable solution?
I'm also using Meshify C Mini with 2x 120mm fans as front intake and 3x 120mm fans as back and top exhaust and also using Hyper 212 Evo Turbo to cool down the CPU. Trying to find an AIO liquid cooler with a 25mm radiator other than EKWB but can't seem to find any in my country as I don't live in US/Canada.
https://linustechtips.com/topic/931848-vrm-cooling-solution-help/
90-100C on VRMs or the CPU itself? VRMs operate at a max of 125C, while the protection mechanics kick in at around 115C to 120C.
Desktop benching:
on the VRMs. The CPU was at around 80c-85c.
I don't prefer to see triple digit on the temperature if possible so that's why I asked if the idea i came up with is viable or not. There's no X370 mATX motherboard so this motherboard is the only choice i have. :/
no point of putting heatsinks on top of it since the ''heatsink'' on that motherboard isn't really a good heatsink it's just a block of metal really
aim a fan at the components i highlighted, all you need is to get some airflow over them and your temps should go down
Specs: Ryzen 9800X3D 5425MHz - ASUS TUF RTX 4080 super - G.Skill Trident Z5 Neo 64GB 6400MT/s CL26 -  Gigabyte X870 AORUS Elite Wifi7 ICE - Torrent Fractal Design white - EVGA 850W Supernova G2 80+ Gold - Noctua NH-U12A
