Hello. I'm a dinosaur at PC building. Hopefully someone can help. I have a PC with 2 GTX 970s from MSI and another with 2 GTX 970s from ASUS. Is it going to hurt either or both PCs if I swap them? The color doesn't match that's why I'm doing this. Thanks, peeps. Hopefully this helps me in my PC woes.
https://linustechtips.com/topic/931714-gpu-swap/
You can SLI them just fine... it doesn't have to be from the same brand only the chip must be the same (GTX 970) do keep in mind that depending where the SLI fingers are located you might be forced to use a flexible bridge.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/931714-gpu-swap/#findComment-11387578
