https://linustechtips.com/topic/931683-plz-help/#findComment-11387323
8 minutes ago, Vented_Swing_6295 said:
1. Please refrain from using 'amps', they are 'amperes'
2. Are you trying to power your PC from a substation?
i7 8700k @ 5.0Ghz | ASUS Strix Z370-F Gaming | Cryorig R1 Ultimate | 16GB Corsair Vengeance LPX DDR4-3000 | ASUS Strix GTX 1080 8GB (A8G) | WD Black 500GB PCIe NVMe | Samsung 750 EVO 120GB | Western Digital Black Series 1TB | Fractal Design Define R6 TG | Corsair RM750x
"Everyone says that I'm incredibly unlucky at the Silicon Lottery. In truth, I just persist in believing that 106°C is an acceptable temperature."
- Me, 2018
https://linustechtips.com/topic/931683-plz-help/#findComment-11387337
You seem to be confused. Amperage at which voltage? How much power is the breaker capable of? Are you even going to hit that number with a mid-range rig? (I assume from that PSU). Those are the questions you should be asking yourself, ONLY if you're going to plug to PC into the same mains you plug your oven, fridge and stuff in, which I highly doubt. There likely is nothing to be worried about.
https://linustechtips.com/topic/931683-plz-help/#findComment-11387354
lets say you are in a 3rd world country where your house has only 12 amp
and you have 2 air conditioners that each take 6 amp to work turning on both will make you have a power outage
Shouldn't each A/C be in a separate circuit with its own breaker?
Anyway, at peak consumption that PSU would use about 3.7A (I used a .9 PF and 220V so correct me if this is wrong)
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
https://linustechtips.com/topic/931683-plz-help/#findComment-11387383
Depends on what you're powering and what voltage the mains runs at. For a 1080 system, you should be looking at ~3A at 110V or a bit over 2A at 230V.
https://linustechtips.com/topic/931683-plz-help/#findComment-11387433
