Hey all, im working on a pc build (I dont have any of the parts yet im waiting till I KNOW what is a good buy) I have never built a PC as of yet so I am kinda flying by the seat of my pants here. Constructive criticism is welcome and advice is needed. So without further adieu here is the list of things I am trying to make into a pc :P
1. Location and budget
Well, Im in Central USA, Minnesota to be exact. And im trying to build this as cheap as possible while still having plenty of performance (lets be honest, that what everyone does right?). My budget is somewhere around $600 USD preferably but the current list is somewhere around 1k.
2.Aim
This is going to be a multipurpose pc, I will be doing some video editing and some recording along with gaming, things like ARK survival evolved, csgo etc. It needs to be able to also do some 3D rendering for Adobe and blender.
3.Monitors
Well Im going to start out with a single monitor, 24 inch 1920x1080 144hz but eventually I will expand to three.
4.Peripherals
I dont have any peripherals currently as I am moving up from a laptop so I will need everything from a keyboard to mouse to monitor.
4.Why im upgrading
Im upgrading for a few reasons. Number one is I just want to build a pc, number two is I need more power to do things like rendering animations. And number four is I currently only have a Laptop, a Dell Latitude e6430 to be exact. Benchmarks and sys info can be found HERE . Once you have a read you will see why I need an upgrade, I am trying to game/record/edit/render on an old laptop with a 14" 1600x900 mat screen.
5.Conclusion & Spec list
Im new to all this as I have already said and im on a budget, used pieces are welcome and if anyone has extra pieces they are willing to sell hit me up as I need to keep the price down (student loans and all).
Thanks in advance to all that reply with help and tips!
Specs:
https://pcpartpicker.com/list/vmHshy
Im trying to get an old Titan Black on eBay....
Here is my amazon list for the current list as I am working on it (note that this list has more pieces then I will buy, its just some possibilities compiled)
https://linustechtips.com/topic/931481-first-pc-build-need-advice/
Although this isn't the optimal setup for the money you can read about what I did with my computer:
https://pcpartpicker.com/b/XwkdnQ
I haven't updated it in a while:
(Now I have the Phanteks P400 Tempered Glass, 24" Dell 1080p and a 3TB hard drive)
It's kinda helpful 9_9
Remember, used parts.
CPU: Intel Core i7 3770 @ 3.91 GHz RAM: G.Skill 4x4GB 2133Mhz DDR3 GPU: AMD HD 7970 3GB SSD: Samsung 840 Evo 500GB PSU: Corsair HX620W  Motherboard: Gigabyte Z68X-UD3H-B3 Case: Phanteks P400 Tempered Glass (Black) Monitor: Dell P2412H, Dell 2012H Keyboard: Razer BlackWidow Ultimate Classic Mouse: Logitech G203 Prodigy HDD: WD Black 3TB
I like the industrial look of that PC case that you used in the build before you upgraded to the P400. I'm a weird one, that doesn't like the common non-unique cases. I always go overboard lol.
CPU i7-7700k 5.5GHz Delidded GPU MSI 1060 6GB ARMOR OCV1 +335/+1000 RAM 16GB 2x8 Corsair Vengeance WLED 2400/3000 C14 COOLER Corsair H100i v1 BOARD MSI Z270 SLI SSD Samsung 960 Evo 250G, x3 2T Samsung 860 Evo HDD WDB 4T, WDB 1T PSU EVGA 650GQ80+M CASE Cougar PanzerS
CPU i7-10700k GPU MSI RTX 2080 Duke POS RAM 32GB 2x16 Corsair Dominator Platinum RGB 3200/3600 CL14 COOLER CM MasterLiquid ML360R RGB Push/Pull BOARD MSI MEG Z490 Ace SSD 980 Pro 500G, 860 Evo 1T PSU EVGA 1000P2 CASE Phanteks Enthoo Luxe TG Black
CPU Pentium G4600 GPU MSI GTX 1080 Armor OCV1 +100/+400 RAM 8GB 2x4 G.SKILL Aegis 2133/3000 CL16 COOLER Corsair H100i v1 BOARD MSI H110M Pro-VD-Plus SSD 860 Evo 1T HDD WDB 500G, WDB 1T PSU EVGA 430W Bronze CASE Deepcool Tesseract/ VIVO
SERVERS i5-3470, i5-3470, i5-4590 GPUS MSI 750Ti 4GB, BFG GTS 250 1GB, GTX 690 RAMS 3x 16GB 2x8 1866 C8 PSUS 2x EVGA 1000T2 COOLERS Stock, Stock, Custom Loop BOARDS Intel, Intel, EVGA Classified SSD x3 860 250G HDDS I don't care to list CASES Optiplex, Optiplex, 2000s Water Case
560HP/607TQ E85 198MPH2000 Audi S4 2.7Bi-Turbo with K04/RS6 Inlets SRM -  DAZ Tune - 2.8L N/A DOHC Heads  -APB Block - Mahle Pistions - JHM Racing H-beam Rods - TheTuner Manifolds - 3.5in to 3in Exhaust with Magnaflow Dual Box - Dual Titanium Exhaust Tips - SAI CNC Delete - S4 Modified Airbox - 85MM Maf- RS4 Intake Manifold p&p RS4 Y-pipe - RS4 Bi-pipes - RS4 Fuel Rail - A8 TTB - Billet Divertervalves - Silicone Hose Everything - SRMv4 Intercoolers - Clutch Fan Delete/Block off - Power Steering Light Pully - FluidAmper - Billet Cam gears - V8 Cam Bolts - ABS Relocate - VW Diesel Oil Pump
what's the most you're willing to spend for everything(monitor and rig)?
1 minute ago, FoxFire said:
Soft cap is 700, hard cap is 1.1k
Mind the personal-ness. Do you have a income source?
2 minutes ago, FoxFire said:
Not at the moment, had to quit my previous income for school, now looking to apply in the next month or so.
Ok. Do you want Intel or AMD?
Also ARK on a i7-7700k and 1060 6GB (in my signature) aren't going to cut it in ARK on Ultra. I need a 1070 overclocked. So keep that in mind, if you want to play Ultra. This was on 2560x1080
at your limit:
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($175.02 @ Amazon)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  ($74.89 @ OutletPC)
Memory: Team - Vulcan 16GB (2 x 8GB) DDR4-3000 Memory  ($152.99 @ Newegg)
Storage: Crucial - MX500 250GB M.2-2280 Solid State Drive  ($72.27 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($42.99 @ OutletPC)
Case: DIYPC - DIY-F2-W MicroATX Mini Tower Case  ($34.98 @ Newegg)
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($34.99 @ Newegg)
Monitor: AOC - G2460PF 24.0" 1920x1080 144Hz Monitor  ($194.70 @ Amazon)
Total: $782.83
Generated by PCPartPicker 2018-05-27 22:27 EDT-0400
https://www.ebay.com/itm/ZOTAC-GeForce-GTX-1070-8GB-GDDR5-Blower-Edition/282981471183?epid=1875705361&hash=item41e30293cf:g:8qwAAOSwQO9a3yE6
PCPartPicker part list: https://pcpartpicker.com/list/tfYqRJ
Price breakdown by merchant: https://pcpartpicker.com/list/tfYqRJ/by_merchant/
CPU: AMD - Ryzen 3 2200G 3.5GHz Quad-Core Processor  ($94.59 @ SuperBiiz)  - Replaces the R3 1200 as AMD's budget offering. The iGPU isn't terribly useful in this situation but might be good for hooking up extra monitors. The Wraith Stealth box cooler is enough for mild OC's
Motherboard: Gigabyte - GA-AB350M-DS3H Micro ATX AM4 Motherboard  ($59.99 @ Amazon)  - Cheap, overclocking friendly, and 4 DIMMs so you can upgrade your RAM easily in future
Memory: Patriot - 8GB (2 x 4GB) DDR4-2133 Memory  ($82.98 @ Amazon) - Cheapest dual-channel DDR4 8GB. Works but 16GB would be a good upgrade
Storage: Team - L5 LITE 3D 240GB 2.5" Solid State Drive  ($54.99 @ Newegg) - No new PC has any right to be booting off a hard drive. I can say from personal experience this is a good SSD and it's cheap.
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($42.99 @ OutletPC)  - The famous WD Blue. It's well known for a reason
Video Card: PNY - GeForce GTX 1060 6GB 6GB XLR8 Gaming OC Video Card  ($313.93 @ Newegg Marketplace) - Cheapest 1060 6GB with a dual fan cooler other than the white ASUS Dual which is known to run quite hot.
Case: Fractal Design - Focus G Mini (Black) MicroATX Mini Tower Case  ($54.99 @ SuperBiiz) - Fractal Design quality, 2 included fans not to mention nice and cheap.
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($34.99 @ Newegg)  - Good PSU, should last you through a number of
Total: $739.45
Generated by PCPartPicker 2018-05-27 22:22 EDT-0400
Should handle 1080p 144HZ in esports titles and 100-ish FPS in more demanding games
CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 ||
LAPTOP: Dell XPS 15 7590
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
Just now, FoxFire said:
Sadly both are above my price limit.
Hmm. You wanted a monitor too right?
3 minutes ago, Crazycatman said:
These are both excessively overkill and unbalanced setups, he can get high FPS with the 1080p monitor I linked in eSports games or even lesser intensive titles like Siege on high just fine.
13 minutes ago, Herman Mcpootis said:
at your limit:
Total: $782.83
There isnt any GPU in this list and the CPU is missing integrated graphics
Why an APU with a 1060? You can game on the integrated graphics themselves, and save up for the 1060 later.
hi.
look at the link on the bottom.
15 minutes ago, Herman Mcpootis said:
Cause i can fit it into the budget and it's miles better than the Vega 8
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
  • 4 weeks later...
Yeah the Antec 900 is weird. It has the most airflow like ever, but it collects dust really fast and everything is difficult to put in and remove.
