If you want small but watercooling friendly, the Fractal Design Define C and Meshify C will be your friends. They are quite small cases but can fit most anything on the market inside :)
Lappy: i7 8750H | GTX 1060 Max Q | 16Gb 2666Mhz RAM | 256Gb SSD | 1TB HDD | 1080p IPS panel @60Hz | Dell G5
https://linustechtips.com/topic/931432-case-for-college/#findComment-11384838
it isnt too terrible large, i have the itx version fits perfectly in my suitcase. and the ATX isnt much larger. But if you want airflow go for meshify C. I just like phanteks looks much more.
CPU: Intel - Core i7-8700K @4.9 GHz 6-Core Processor CPU Cooler: be quiet! - Dark Rock Pro 3 67.8 CFM Fluid Dynamic Bearing CPU CoolerMotherboard: MSI - Z370I GAMING PRO CARBON AC Mini ITX LGA1151 Motherboard Memory: PNY - Anarchy 16GB (2 x 8GB) DDR4 @3000 MemoryStorage: 960 evo 500gbVideo Card:place holderCase: Phanteks - Enthoo EVOLV ITX TG (Black) Mini ITX Desktop Case Power Supply:SeaSonic - EVO Edition 620W 80+ Bronze Certified Fully-Modular ATX Power Supply Case Fan: be quiet! - SilentWings 3 pwm 59.5 CFM  140mm Fan Case Fan: be quiet! - SilentWings 3 PWM High-Speed 73.3 CFM  120mm Fan Case Fan: be quiet! - SilentWings 3 PWM High-Speed 73.3 CFM  120mm Fan Monitor: Dell - S2716DG 27.0" 2560x1440 144Hz Monitor Mouse: Place holder Sony H.ear on Wireless Noise Cancelling Headphone, Charcoal Black (MDR100ABN/B)  LEOBOG K26 Wired RGB Mechanical Keyboard,Gaming Keyboard,RGB Color Backlight,104 Key,Anti-Ghosting For Full Key,Blue Switches,Aluminum Chassis,Detachable wrist rest,PC,Computer, Laptop,BLACK (Black)EZDIY-FAB Sleeved Cable - Cable extension for power supply with extra-sleeved 24 PIN 8PIN 6PIN 4+4 PIN With COMBS- Black Grey
pcpartpicker: https://pcpartpicker.com/user/resdal42/saved/sCW6XL
https://linustechtips.com/topic/931432-case-for-college/#findComment-11384963
52 minutes ago, jamie.k.hofer said:
So I am looking for a case to throw my X99 rig into for college, but I want something compact, sexy, and that could support water cooling. I love aluminum and tempered glass, maybe something like an Enthoo Evolv? It is a bit large though.
NCase M1, But the glass side is sold separate.
https://www.sfflab.com/products/ncase_m1
https://www.sfflab.com/collections/parts/products/ncase_m1-window-panel
https://linustechtips.com/topic/931432-case-for-college/#findComment-11385027
