4K Monitor, GPU?
Arioch
Hello, i have a question for you guys and ladies..
My father (he keeps giving me gifts that later on make me cry cause i have to spend more and more to be able to reach what he bought me (read on and ull understand what i mean)..
Poor me, has an R9 380X gaming 4G GPU (yeah it sux, shut up :P )
Last Black Friday my Father bought me a Samsung 3840x2160@60Hz (dont recall the model) Monitor..
So question is, will my GPU NOT screw my gaming life like A LOT?? i know it will screw it up, but how much?
Also since my PC is basically dead (another post on troubleshooting about this), and i will be fixing a new one shortly (several months to collect around 1200 EUR needed for the new one), any GPU under budget reccomendations? thnx for your time!!
The only GPUs capable of driving frames for 4k is 1080ti, Titan Xp or Titan V. Beyond that, if you want to keep using the 380x, you can downscale the games from 4k to a more manageable 1440p or 1080p.
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
thats what im doing now, but it seems (to my eyes at least) that the screen works worse than my old 22" wide LG monitor .. might be in my mind only?
It will be less sharp and stuff for sure since its not its native resolution.
"Black Out"
ok thnx a lot buddy! ill check which card of those you mentioned will NOT make me wanna throw the monitor out of the window :P:P ! Thnx again!
That's not true, as long as you're willing to lower the settings a little bit a 1080 or even a 1070 (or either of the Vega cards) is enough. My r9 fury runs doom 2016 at 4k with pretty high settings, a 1080 would have no problems even with newer titles than that.
I also recommend buying used, if the card hasn't been abused (you can generally tell) they're pretty much as good as new. If you want to know how scaling affects your image quality, I have a link in my signature to a thread I made that explains it.
sudo chmod -R 000 /*
As soon as I go home from work, ill check it out for sure!! Thnx for the help and info!!
P.S. if you have the time, I have a post in troubleshooting cause my pc is failing hard!!
I would like ur opinion about it, to see if I can save it as 2nd while ill build my new one!!
The best is gtx 1080ti you may buy tata xp but it's not worth it like extra 10fps for Extra 200 euro is not worth it. The 1080 ti is the best buy for 4k at 60hz.
AMD Ryzen 3 1300x @3.9 ghz
Asus prime b-350 motherboard
16 GB Corsair vengeance ddr4 ram @2400 MHz
4 tb hhd
Samsung 240 GB SSD
MSI gtx 1060 6 GB OC @2.0 ghz
Corsair Vs 550 PSU
Chiptonex gx1000 V2 witch addition 3 front RGB Corsair fans 2 Corsair RGB fans at top and the inbuilt one at the back
Logitech g502 spectrum RGB mouse
Razer cynosa chroma RGB keyboard
Prism 63391 RGB mouse pad
Readgear gmaing headset
Samsung 75hz 1440p curved monitor
