I've run into an issue where my Num Lock key does not function unless the Shift key is pressed.  I can fix it by restarting my computer, but having to do that just so I can auto run in a video game is a bit frustrating.
Has anybody encountered this problem before?
I recently had to install the new Windows 10 update, other than that nothing in my system has changed.
I use a Das Keyboard connected with the PS/2 adapter.
