Hi,
i just got the recent windows update (build 17134.48) and it randomly started deleting all my files each time i went into a folder. every time a folder is opened it automatically start deleting the contents and does not even ask for permission.
Is there any way of fixing this or is this just a problem with windows catching on complete nonsense
https://linustechtips.com/topic/930938-please-help/
2 hours ago, AskTJ said:
This might be an issue with your antivirus. Try and install another antivirus and see if that solves the issue.
I deleted the antivirus software (McAfee) and downloaded Avast but the issue still persists.
Edited by AngryMonkey420
Found out something
https://linustechtips.com/topic/930938-please-help/#findComment-11380827
