So i am looking for a blu ray player that is thinner than the 5.25' standard external bay and it must be shorter than 6.2' length wise, , must be sata, and also it must be motorized.
why? for a ps2 pc conversion of course.
i want to replace the original hard drive with a blu ray one (i will settle for dvd if no thin blu ray drives exist), however most drives are 5.25 in. and that is simply too big for the ps2.
anyone know of a drive like this or know where to look? (other than newegg or amazon ofc)
https://linustechtips.com/topic/930791-thin-blu-ray-player/
https://www.newegg.com/Product/Product.aspx?Item=9SIA4UB50N7587
you may also be able to order it directly from asus.
its basically the replacement for their laptop blue ray drive, but it should work for what you need
How do Reavers clean their spears?
|Specs in profile|
The Wheel of Time turns, and Ages come and pass, leaving memories that become legend. Legend fades to myth, and even myth is long forgotten when the Age that gave it birth comes again.
https://linustechtips.com/topic/930791-thin-blu-ray-player/#findComment-11380237
