I am having a problem where my oculus sensors are working perfectly, but if I plug my t500RS wheel into the front IO of my case one of my sensors starts disconnecting and reconnecting constantly. But my sensor is plugged in to the back of the motherboard. Could this be caused by the USB controller or board cant handle so much throughput at the same time? I remember this happening once before and then a restart fixed it, but trying to troubleshoot whats causing it so I  havent done that yet. Also sometimes when I have been using my PC for a few hour and then decide to play VR I only see black in the HMD, or the headset starts disconnecting and reconnecting. also fixed by restart but its a bit annoying. Anyone experienced the same issues? Ive unchecked the box to allow the sensors to go to sleep, Ive tried different USB ports, uninstalling and reinstalling drivers..
Winning an argument with a woman step by step
step one - talk to her
step two - fight with her for 2 hours even if you are really right
step three - admit that she is right for the sake of your safety
step four - realize that you have accomplished nothing and she still thinks you were wrong and now she thinks you are even more stupid
GTX1080ti, I5-4690k, ASUS Z97 PRO-GAMER, 8GB DDR3 1600mhz, Hyper 212 EVO, Tt view 31 RGB.
https://linustechtips.com/topic/930655-oculus-rift-sensor-problem/
