display problem
jackthehack
i have installed win10 64 and while updating drivers i got this problem what should i do to fix it
I'm confused, what is the actual problem?
EDIT: I noticed the icons and task bar were off screen. Try change the scaling in the settings or swapping the resolution back and forth.
like the display is zoomed in and task bar and desktop icons are almost hidden i tried updating nvidia display adapter
but nothing changed
but nothing changed
Did you try swapping resolution and swapping back?
Have you tried uninstalling the graphics drivers and reinstalling them?
Have you tried using your monitors auto adjust feature to try fix it?
i tried uninstalling the driver it solved the problem but after rebooting the driver was auto installed and the problem came back
