I'm planning to get a commander pro pack with 3 ml140 pro rgb fans for my case and also some rgb strip hub thingies but i can't decide between the lighting node pro or hue+. I don't really care if i have to operate 2 programs i just wanna know which one is more visually appealing and better looking.
poop
https://linustechtips.com/topic/929855-lighting-node-pro-vs-hue/
If your running the RGB fans from Corsair you would be better going to the Commander Pro unit as it will require Corsair's Ecosystem to control the lighting. Between the Hue+ and Corsair LED strips both are addressable options so they would be able to have if not the same a very similar effect.
