R9 390 Overclocking Help
Go to solution Solved by DragonTamer1,
Not all aplications will see a boost in performance from a memory overclock, though with AMD memory overclocking is typically just as important as core overclocks. Its possible your card is not bottlenecked by its memory.
If you stick your water cooler on, it certainly will drop your temps but you won't get much more of an oveclock out of it. You can lower its power consumption if you cool it enough, but that is about it.
Im well aware that the r9 390 is a terrible card to overclock and the Strix r9 390 doesnt cool the vrm's very well, but i have 2 questions about my overclock.
I managed to get my r9 390 strix to 1125mhz core with +10% voltage
Thats not weird
I kept upping the memory clock to see how far it would go and it finally got to 1950Mhz and was fine, but i was seeing no gains in performance. It either was not actually applying the clock i was setting (sometimes when an overclock fails it reverts to defaults, but it claims it was running at 1950 mhz) or i got the best memory in the history of the world for r9 390's, but it just didn't make a difference. My first question is what is happening there?
Secondly, would water cooling the card with something like the Kraken G12 (i already have a AIO just sitting and collecting dust) provide a better overclock? Would putting heat sinks directly on the vrm's provide a better overclock? I've watched a couple videos with conflicting results so what can i do, if anything, to up the clock on this card?
https://linustechtips.com/topic/929601-r9-390-overclocking-help/
Intel Xeon 1650 V0 (4.4GHz @1.4V), ASRock X79 Extreme6, 32GB of HyperX 1866, Sapphire Nitro+ 5700XT, Silverstone Redline (black) RL05BB-W, Crucial MX500 500GB SSD, TeamGroup GX2 512GB SSD, WD AV-25 1TB 2.5" HDD with generic Chinese 120GB SSD as cache, x2 Seagate 2TB SSHD(RAID 0) with generic Chinese 240GB SSD as cache, SeaSonic Focus Plus Gold 850, x2 Acer H236HL, Acer V277U be quiet! Dark Rock Pro 4, Logitech K120, Tecknet "Gaming" mouse, Creative Inspire T2900, HyperX Cloud Flight Wireless headset, Windows 10 Pro 64 bit
thanks
