Do you need GPU support? HDDs or all SSD? Need a DVD drive?
A Jonsbo C2 is the smallest case you can get that can fit a mATX motherboard, ATX PSU, and up to a triple slot GPU.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/929405-small-cheap-uatx-case/#findComment-11365153
37 minutes ago, saabgirl said:
So I'm looking for a small as possible but cheap uATX/mATX case. I've found this so far, but that's it. Can be thin or a cube, just needing it to take up the least space possible. Any suggestions?
I bought one of these a few months ago
https://www.newegg.com/Product/Product.aspx?Item=N82E16811353063
Works great, comes with green or red lights, good design, good airflow, well thought out build construction.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/929405-small-cheap-uatx-case/#findComment-11365188
No need for a DVD drive, just running a single GTX1060 and a single hard drive.
That could be an option. I just don't really have a need for a drive bay, or I would jump on it.
https://linustechtips.com/topic/929405-small-cheap-uatx-case/#findComment-11368699
Yeah, if you can find one, I'd go with the Jonsbo C2.
SPECS:
https://linustechtips.com/topic/929405-small-cheap-uatx-case/#findComment-11368703
