So I bought the evga 450 bt (https://www.evga.com/products/product.aspx?pn=100-BT-0450-K1) and do not see sata power on it. Do I need a molex to sata power connector? Or am I just stupid and all I need is sata. Sorry guys, I’m a scrub. The hdd I have also seems to have a 4 pin slot, and I have no clue what that is.
another question is, is the larger looking sata connector the sata power orrrrrr?
I hAve an unfinished pc build. Pls dont bully for not having one yet or i cry.
https://linustechtips.com/topic/929261-sata-power/
A 4pin slot is molex power, which that PSU has. It also has regular SATA power cables.
Computer engineering PhD student and RFML researcher
Daily Driver:
CPU: Ryzen 7 4800H | GPU: RTX 2060 | RAM: 32GB DDR4 3200MHz C16 | OS: Debian 13
Gaming PC:
CPU: Ryzen 5 5600X | GPU: EVGA RTX 2080Ti | RAM: 32GB DDR4 3200MHz C16 | OS: Windows 11
https://linustechtips.com/topic/929261-sata-power/#findComment-11363901
It says right there on the website. It comes with 2 SATA chains, each with 2 connectors, 45cm and 57cm from the PSU.
Why did you get the BT? The CX/CXM usually costs about the same.
The 4 tiny pins on the HDD aren't needed, you don't need to plug them in.
Edited by seon123
Something something
https://linustechtips.com/topic/929261-sata-power/#findComment-11363904
It’s like super small though and I have no clue what part is needed. It’s definitely not molex is my point. It’s a lot smaller than molex.
https://linustechtips.com/topic/929261-sata-power/#findComment-11363919
Can you show me what the sata chain looks like.
https://linustechtips.com/topic/929261-sata-power/#findComment-11363931
Probably jumpers then. Those are for old-school configuration purposes. Not necessary in 99.9% of cases these days.
https://linustechtips.com/topic/929261-sata-power/#findComment-11363968
Thank you!
11 minutes ago, Sylvie05 said:
Literally took two seconds to google.
Thank you as well.  That actually helps so much
https://linustechtips.com/topic/929261-sata-power/#findComment-11363997
