need guide in psu
Go to solution Solved by Jurrunio,
1 hour ago, hakim said:
what do you meant by that ???
im considering the masterwatt 550w if you say thats a good one . i really want the focus+ gold 550 , but my budget not allowing it ??
instead of using 1 for 7 years, use 2 for 10 years
hello guys , im new & need help on choosing the right psu
im planning to buy a new psu for my current system that can be safe transfer to my next build in about 1-2 month
i need a new psu cause the old one is old enough cx500 (2014 if not wrong,green strip in the box)
current system
core2quad Q8400 2,66ghz runs @3 ghz(+150mv offset)
lga 775 mobo
g41 chipset = asus p5g41t mlx
2x4gb dual channel ddr3 1333mhz
cpu cooler gammaxx 300
3x12cm fan casing
1ssd
3 hdd 7200rpm sata3
msi gtx 650 oc 1gb ddr5
mouse keyboard wireless
headphone 3,5mm jack
17inch led monitor 1366x768 60hz
next build in 2 month
ryzen 5 2400g
no vga
will overclock the gpu @1500mhz 1,3v
mobo asrock ab350 pro 4 atx
2x8gb ddr4 3200mhz
other hardware willbe transfer from the old build
current build n the next one will be on about 12 hours a day ( gaming & multitask for office stuff )
hope i can get some advice for cheap/budget psu with good quality n long life time , a few selection will be great n from there i will pick one the best for my budget .
very very much thank you in advance if any one can help me with this matter .
note:
i saw a few option from looking around,
(with no order of the best)
andyson h6 ad-f60gg 600w 80+gold
antec neoECO II 450w
cooler master masterwatt 550w
corsair cx450m
did you guys think that a good selection list ?
or maybe you guys have another selection list ?
what is the best quality among those selection ? is there one
i prefer cheap if can , best quality , long life time . maybe i can do another upgrade after 5-7 years ?
cant go wrong with psu , better lower the hardware than using a bad psu , right ?
https://linustechtips.com/topic/929198-need-guide-in-psu/
the best here is the cooler master masterwatt, followed by the corsair cx450m. Never heard of the andyson, and the antec one is usable at best.
yes
I'm only as confident on my PSU as the brand, In this case, the Masterwatt and CX450M both have 5 years of warranty. If you want a longer warranty, the cheapest options are usually Seasonic or EVGA, though only 80+ Gold units or above from these two companies are great.
Desktop benching:
https://linustechtips.com/topic/929198-need-guide-in-psu/#findComment-11363317
20 minutes ago, hakim said:
how about seasonic s12g 550w is that a good quality psu ??
focus plus gold is too much for me , that one s12g is a cheaper one 80+gold
what do you think / know about the seasonic s12g 550w ?
Even this only has 5 years warranty.
But really, you dont have to get one with longer warranty. The masterwatt will do just fine. Just swap them out more often if you're worried.
Desktop benching:
https://linustechtips.com/topic/929198-need-guide-in-psu/#findComment-11363405
Desktop benching:
https://linustechtips.com/topic/929198-need-guide-in-psu/#findComment-11363806
