Improving PC Audio w/ DAC?
I'm going to try and keep this as simple as possible. A few years ago I invested in some V-MODA M100s which I use for pretty much everything, I currently have them hooked up via Optical to a SMSL SD793-II which was recommended to me on these forums. Unfortunately, in moving furniture It has been damaged so I thought now would be the best time to consider an upgrade, If there's a fairly priced one available. I'm looking to spend around the £100 mark, I wouldn't mind going over but the purchase may have to wait a while.
need to have the optical connection, that is my only requirement.
https://linustechtips.com/topic/928835-improving-pc-audio-w-dac/
What are you looking for, a pure amp (like the Magni 3) or a DAC combo type (like your SD793-II)? Also, one question I'd like to ask of you is this: Is a separate DAC stack/combo or amp really necessary? I had the M100 and it can be easily driven by even a handphone (I was using an LG handphone - NOT Quad DAC model - and my Sony Xperia Z5 Premium.
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
Schiit Stack is a popular one.  I bought the Topping A30/D30 stack off mass drop for the same price range.  Similar performance as well.  The cool thing with the Toppin is that the Op Amp is easily replaceable to give you a different sound.  I have a pair of Burson V5is in the mail to give the amp a little better quality.
Otherwise, you can get another S.M.S.L?
