Hi guys I'm looking for second opinions on a build here, I went to r/buildmeapc for some build options, and I got one that looks alright.
My budget is $1100, I did ask if I could reuse my current PSU which is Corsair 600W 80+ Bronze Cert ATX, I'm not sure if I should get a nicer one or just reuse.  Also I might need a hard disk drive, my current one is actually close to being full, but I'm wondering if it's fine to go without one.  Any advice is welcomed, thanks!
Here's the suggested build I got:
PCPartPicker part list: https://pcpartpicker.com/list/rWb3yX
Price breakdown by merchant: https://pcpartpicker.com/list/rWb3yX/by_merchant/
CPU: Intel - Core i5-8600K 3.6GHz 6-Core Processor  ($238.99 @ Amazon)
CPU Cooler: Cooler Master - Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($27.89 @ OutletPC)
Motherboard: Asus - ROG STRIX Z370-E GAMING ATX LGA1151 Motherboard  ($188.89 @ B&H)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($164.99 @ Newegg)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive  ($99.99 @ Samsung)
Video Card: EVGA - GeForce GTX 1060 6GB 6GB SC GAMING Video Card  ($299.99 @ Amazon)
Case: NZXT - S340 (White) ATX Mid Tower Case  ($49.99 @ SuperBiiz)
Power Supply: EVGA - 500W 80+ Bronze Certified ATX Power Supply  ($34.99 @ B&H)
Total: $1105.72
Generated by PCPartPicker 2018-05-19 09:48 EDT-0400
https://linustechtips.com/topic/928544-pc-build-opinions/
I recently had my old psu die so I bought a new one, however I am going to build a new system and even though my new psu is about 3 months old I would not consider using it in my new build. I would not use your old psu and also go for at the very least a gold rated psu. Are you planning to overclock? if not you do not need a motherboard with all the OC features it has so you could go for a cheaper model.
https://linustechtips.com/topic/928544-pc-build-opinions/#findComment-11357737
why an 8600k and bona-fide z370 board just to get a cheapo low-end PSU with it?
https://linustechtips.com/topic/928544-pc-build-opinions/#findComment-11357755
Is your PC strictly for gaming?
Because if it is, then consider this build: https://pcpartpicker.com/list/cvYMbX
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/928544-pc-build-opinions/#findComment-11357756
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor  ($178.89 @ OutletPC)
Motherboard: Gigabyte - B360M DS3H Micro ATX LGA1151 Motherboard  ($65.99 @ SuperBiiz)
Memory: Team - T-Force / Night Hawk 16GB (2 x 8GB) DDR4-3200 Memory  ($160.29 @ Newegg)
Storage: Crucial - MX500 250GB M.2-2280 Solid State Drive  ($72.27 @ Amazon)
Video Card: Zotac - GeForce GTX 1080 8GB Mini Video Card  ($529.99 @ Newegg)
Case: DIYPC - DIY-F2-W MicroATX Mini Tower Case  ($34.98 @ Newegg)
Power Supply: SeaSonic - FOCUS Gold 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($59.99 @ SuperBiiz)
Total: $1102.40
Generated by PCPartPicker 2018-05-19 10:12 EDT-0400
https://linustechtips.com/topic/928544-pc-build-opinions/#findComment-11357765
