Hey all!  I need some help planning my next build.  My budget is going to be $800, and I would like to be able to do 1440p/60fps on max settings, but if I have to settle for 1080/120, I am fine with that.
My current build is thus:
CASE: CoolerMaster Storm Trooper
CPU: Intel i5-4670K
MOBO: Asus Maximus VI Hero
RAM: 8GB G.Skill Ripjaws DDR3 2133
GPU: EVGA GTX680 2GB
Cooler: Enermax Black Twister
SSD: Samsung 840 EVO 120GB
HDD: 1TB WD Black
PSU: Corsair HX650
As you can see my current build is just a wee bit out of date, and I feel that it is time for an upgrade.  I can most likely transfer over the SSD, HDD, PSU, and the optical drive (if need be) to cut down on costs.  Mainly, I am looking for a PC to go in a mid-tower or smaller case since I want to decrease the amount of space my PC takes up, and I am leaning towards a Ryzen build.  Any help/suggestions you guys can offer is greatly appreciated.
https://linustechtips.com/topic/927862-800-build-help/
Just now, hconverse02 said:
1070ti/ryzen 5? With ram that might be over budget. Do you need a monitor too?
I am working on getting a monitor separate from the build budget.  The $800 is strictly for the pc build.  As I said, If I have to go 1080p/120fps then I am fine with that.
https://linustechtips.com/topic/927862-800-build-help/#findComment-11351742
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor  ($175.69 @ OutletPC)
Motherboard: MSI - B350 PC MATE ATX AM4 Motherboard  ($69.90 @ OutletPC)
Memory: Team - Dark 16GB (2 x 8GB) DDR4-3000 Memory  ($159.99 @ Newegg)
Video Card: MSI - GeForce GTX 1070 Ti 8GB Video Card  ($484.98 @ Newegg)
Total: $890.56
Generated by PCPartPicker 2018-05-17 09:52 EDT-0400
A bit over budget, but it will get 1440p 60+ fps done
https://linustechtips.com/topic/927862-800-build-help/#findComment-11351757
Total: $890.56
Where is the RAM?
https://linustechtips.com/topic/927862-800-build-help/#findComment-11351762
i'd just recommend getting a 4770k/4790k, another 8gb of ram and a better GPU, case if you want a smaller one too.
https://linustechtips.com/topic/927862-800-build-help/#findComment-11351769
I wouldn't upgrade the CPU, just OC it a little.  I was running that with a 1080Ti and playing 3440x1440 60fps+ without issues.    It's got great gaming chops and can easily be OC'd to 4.4Ghz+ on inexpensive air.
Since you want to go 1440p/60, you'll be needing more GPU than CPU.  Plus, Ryzen 5 isn't better for gaming than your current chip really, it's more of a lateral move.  Unless you're streaming while you play, I wouldn't upgrade just yet.
I would recommend another 8 GB of RAM, a 1070Ti or better, and more SSD love.  Just another opinion, but I honestly don't think you need to upgrade the CPU/mobo/RAM just to have similar performance.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/927862-800-build-help/#findComment-11351783
https://www.ebay.com/itm/Intel-Core-i7-4770K-3-5GHz-Quad-Core-Desktop-Processor/192541464110?epid=165728524&hash=item2cd45d962e:g:WIUAAOSw8Opa-1MV $180
Memory: Patriot - Viper 3 8GB (2 x 4GB) DDR3-2133 Memory  ($63.99 @ Amazon)
Video Card: MSI - GeForce GTX 1070 Ti 8GB DUKE Video Card  ($474.98 @ Newegg)
Case: Fractal Design - Meshify C White TG ATX Mid Tower Case  ($79.99 @ Amazon)
Total: $618.96
Generated by PCPartPicker 2018-05-17 10:01 EDT-0400
https://linustechtips.com/topic/927862-800-build-help/#findComment-11351793
Total: $618.96
Save some scratch and skip the i7 upgrade, too minimal for the money IMO.  +1 for the Meshify C tho :)
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/927862-800-build-help/#findComment-11351798
the i5 will bottleneck the 1070ti at higher refresh rates so might as well. he can get some of the money back by selling the i5 anyways.
https://linustechtips.com/topic/927862-800-build-help/#findComment-11351808
Provided he sells then i5, then I can back that play.  That's the caveat.  For $180 out of pocket, no.  But for $50 or so net... yeah.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/927862-800-build-help/#findComment-11351862
CPU: Intel i5-4670K
HDD: 1TB WD Black
PSU: Corsair HX650
check this out: https://pcpartpicker.com/list/ckcpHh
PCPartPicker part list: https://pcpartpicker.com/list/ckcpHh
Price breakdown by merchant: https://pcpartpicker.com/list/ckcpHh/by_merchant/
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor  ($178.89 @ OutletPC)
Motherboard: Gigabyte - B360M DS3H Micro ATX LGA1151 Motherboard  ($65.99 @ SuperBiiz)
Memory: Team - T-Force Delta RGB 8GB (1 x 8GB) DDR4-2400 Memory  ($90.98 @ Newegg)
Storage: Kingston - A400 120GB 2.5" Solid State Drive  ($39.99 @ Amazon)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($43.09 @ SuperBiiz)
Video Card: MSI - GeForce GTX 1060 6GB 6GB Video Card  ($284.98 @ Newegg)
Case: Fractal Design - Meshify C Mini Dark TG MicroATX Mini Tower Case  ($84.99 @ Newegg)
Power Supply: Cooler Master - MasterWatt 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($31.65 @ Newegg)
Total: $820.56
Generated by PCPartPicker 2018-05-17 10:28 EDT-0400
you'll be able to hit 60@1440@max in 90 percent of games, in some you will have go down to high if you don't want 45-50 fps. you could step down to the i3 8300 but i don't think its worth imo, stay with the 8400. go with a smaller card so you can go mini case in the future if you would want to do that.
you might want to get a cheaper case, if you don't care much about tempered glass, you can go for the dr zaber sentry, i think it supports M-ATX. inwin 301 is also an option.
total cost is $820.
https://linustechtips.com/topic/927862-800-build-help/#findComment-11351873
