Sometimes, it depends on your computer. It doesn't say everything on the spec page. You could install an SSD for the OS and if there's extra cables, use the hard drive for data. If there's an extra pcie slot, you could put in a GPU BUT you have to first check if there's cables from the power supply to connect to it, and if not you'd have to get something like a 1050 ti which requires no external power. You also have to check what the power supply is rated for, prebuilt PC's generally have low wattage rated PSUs.
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
https://linustechtips.com/topic/927754-i-need-help/#findComment-11350562
looks like a smaller 1050/ti could fit.
https://linustechtips.com/topic/927754-i-need-help/#findComment-11350564
It has a non standard power supply, you won't be getting anything high end out of that.
CPU: Core i7 4970K | MOBO: Asus Z87 Pro | RAM: 32GBs of G.Skill Ares 1866 | GPU: MSI GAMING X GTX 1070 | STOR: 2 X Crucial BX100 250GB, 2 x WD Blk 1TB (mirror),WD Blk 500GB | CASE: Cooler Master HAF 932 Advanced | PSU: EVGA SUPERNOVA G2 750W | COOL: Cooler Master Hyper T4 | DISP: 21" 1080P POS | KB: MS Keyboard | MAU5: Redragon NEMEANLION | MIC: Snowball Blue | OS: Win 8.1 Pro x64, (Working on Arch for dual boot) |
https://linustechtips.com/topic/927754-i-need-help/#findComment-11350568
11 minutes ago, Fxnatic said:
or do i only buy the 1050ti?
i need to learn more about computers and how they work...
Will you be using it for gaming? If not, the SSD is the only major upgrade you can do that you'll see a huge difference in. If you notice you're using most of the 8gb of ram installed, another stick would help.
https://linustechtips.com/topic/927754-i-need-help/#findComment-11350602
40 minutes ago, Fxnatic said:
so i should buy a better power supply and a 1050i?
for gaming, get a 1050ti, check wattage and form factor before buying a new psu.
https://linustechtips.com/topic/927754-i-need-help/#findComment-11350640
