Specified VID for 5820k?
Solved by done12many2,
22 minutes ago, steffeeh said:I'm looking into LLC and experimenting with the overclock on my i7 5820k CPU, but I can't find the specified safe voltage from Intel aka the VID, which would be very helpful to know when experimenting with LLC.
Does anyone know?
There is no specified VID for all 5820k CPUs. The VID programmed to your particular 5820k will be different than another 5820k. In addition to that, the VID curve for each core can also be different.
VID is definitely good to know as you begin tweaking voltage for your application as it allows you to compare what Intel specified to what you commanded.
HWInfo64 will report VID for each core. https://www.hwinfo.com/download.php
Good luck.
