I'm planning on building a cheap secondary PC and I want to try AMD for the first time. I'm planning on going with the Ryzen 3 2200G because it has integrated graphics and I don't plan on running a graphics card on this PC.
What I'm worried about is that I've heard that some B350 motherboards require a BIOS update to function with the new Ryzen CPUs. How do I ensure I get a mobo that'll function out of the box with the CPU I picked? And if I do get a motherboard that requires a BIOS update will I even be able to get into BIOS without the CPU? Or will I have to find another AM4 socket CPU first to use to update the bios and then slot in the Ryzen 3 2200G?
Current build plan:
Ryzen 3 2200G
Asus Prime B350-M
Corsair Vengeance 8GB DDR4
WD BLack 256GB NVME SSD
Corsair CX 450W
https://linustechtips.com/topic/926699-help-with-ryzen-3-build/
You have to contact the seller and ask them if the BIOS is up-to-date.
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
https://linustechtips.com/topic/926699-help-with-ryzen-3-build/#findComment-11339936
Just now, Alfie said:
I'm planning on buying this entirely on Amazon. How does one contact the seller if it's officially from the Asus seller on Amazon?
I was going to add that it becomes difficult if you are buying off of Amazon... I would say that it's next to impossible. Your best bet is buying it off a third-party seller that is using Amazon marketplace. You can contact them by going on their profile (but they won't have stuff such as one day delivery).
You can try to get the motherboard, if it does not boot just return it to Amazon and look elsewhere... Retailers update the BIOS for you.
Unraid Server
https://linustechtips.com/topic/926699-help-with-ryzen-3-build/#findComment-11339944
19 minutes ago, Alfie said:
Go for the ASrock pro 4, usually the best value board, most of the boards should be updated by now.
Make sure to get 2800mhz RAM or better
no reason to go NVME unless you already have it or it's pretty cheap
https://linustechtips.com/topic/926699-help-with-ryzen-3-build/#findComment-11339947
I'm just going to be using this PC purely for web browsing and backup PC incase anything happens with my main rig, so what if I just go down tot he A8-9600? It surely should have no BIOS update required?
https://linustechtips.com/topic/926699-help-with-ryzen-3-build/#findComment-11340082
100% not worth getting anything below the R3 2200G
https://linustechtips.com/topic/926699-help-with-ryzen-3-build/#findComment-11340106
Current build plan:
Ryzen 3 2200G
Asus Prime B350-M
Corsair CX 450W
Build something like this....
If u have a microcenter nearby, then get their combo deals....they usually do bios upgrades for free if u get the combo deals....
CPU: AMD - Ryzen 3 2200G 3.5GHz Quad-Core Processor  ($94.59 @ SuperBiiz)
Motherboard: ASRock - AB350M Pro4 Micro ATX AM4 Motherboard  ($74.39 @ OutletPC)
Memory: Team - Vulcan 8GB (2 x 4GB) DDR4-3000 Memory  ($90.98 @ Newegg)
Storage: Crucial - MX500 250GB 2.5" Solid State Drive  ($69.99 @ Amazon)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.79 @ OutletPC)
Case: Cooler Master - MasterBox Q300L MicroATX Mini Tower Case  ($38.99 @ SuperBiiz)
Power Supply: Cooler Master - MasterWatt 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($31.65 @ Newegg)
Total: $460.38
Generated by PCPartPicker 2018-05-14 07:05 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/926699-help-with-ryzen-3-build/#findComment-11341111
