Need help
Jacob Waldman
When i push power it boots for a second then shuts off, its not the ram or cpu, but whe i take out the cpu cable it boots. PLEASE HELP.
You need to see if there is any post code in the first place. And how are you sure it is not the RAM or the CPU?
