Hey guys,
My story is a bit of a weird one. A few days ago i bought this intel board on ebay for $100, it was made clear that there was damage done to the board (scratches on the pcb) but they didn't look to bad to I figured what the heck. (see attached pics for scratches on mobo)
The board came in yesterday, and after plugging in just the psu, it would not turn on, which I found a bit odd, but then I plugged my ram and my cpu in and it turned on, so might be a feature of the board? Either way, after setting everything up, it worked flawlessly for the whole day. Today, I went to turn it on and nope... Post code 33. so I restarted it. Post code A9. No beeps for either of them. Now when I try it just doesn't even bother trying, and just sits on 00. I tried removing all but one sticks of ram, all the ram, unplugging some unneeded usb devices, and clearing the cmos, all with no luck.
Is there anything else I should try before trying to re-solder the connections on the back? Thanks in advance!
My Specs:
Mobo: Intel DX79SI
CPU: Intel i7-3930k
GPU: Nvidia GTX 950 (msi, no 6pin power)
Cooler: Corsair H115i (280 rad)
Ram: 12gb (2x 2gb Ripjaws, 2x 4gb Patriot)
PSU: Corsair CX600M
Drives: Samsung 850 500GB SSD, 3TB WD Drive
Case: NZXT S340 Elite
Let me know if theres any other info you need. I will be home later today to test what you guys come up with
Please note though, I do not have another cpu to test, this is my only one, but I have a new board coming in from china eventually (between now and like end of June)
Update 1: Removed the mobo from case, checked pins, all seemed good. I also cleaned out the scratches with a parts cleaner (Super Solv Multi-purpose solvent), and I've also tried a different psu and both sets of ram, no luck. at this point i have nothing but the cpu and psu plugged into the board and it just sits at 00, no beeps or anything, but i do find it weird that the (red) standby
LED comes on after a few seconds. I have no idea what to do at this point.
Edited by Mattinator123
update
https://linustechtips.com/topic/926502-intel-dx79si-post-code-00/
