Hello, so today I'm getting this error on Windows10 after running Malwarebytes. It says: There was a problem starting C:/Windows/system32/C_65003.NL (The specified module could not be found.)
I keep pressing OK, but it keeps showing up over and over again. Can someone tell me how do I get rid of this?
Error Image:
Click
https://linustechtips.com/topic/926147-runddl-problem/
sounds like a missing or corrupted file. Try running the windows 10 repair. It may require you to have an ISO readily available to pull the files from.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/926147-runddl-problem/#findComment-11334816
Is not a system file that I would recognize, its likely from some other third party software, or a virus.
There is no such file on my Malwarebytes installation, so its probably due to some malware. I would recommend running more than one malware scan to check, https://www.trendmicro.com/en_us/forHome/products/housecall.html is a great scan if your in a tough spot and can still open a browser.
https://linustechtips.com/topic/926147-runddl-problem/#findComment-11336076
