Which microphone should I get? Please help.
CPU: i7 8700 GPU: Asus ROG Strix GTX 1080 Mobo: Gigabyte Z370 Gaming 5 Ram: 16GB EVGA SuperSC SSD: Samsung 850 EVO 250GB
HDD: Seagate Barracuda 2TB PSU: TX650M Case: NZXT S340 Elite OS: Windows 10 Mouse: Logitech G403 Mouse Mat: HyperX Fury S Pro XL
Keyboard: CM Masterkeys Pro S (reds) Headphones: Sennheiser HD598 Monitor: Asus 24' MG248QR Devices: IPhone 11 Pro Max + 13' Macbook Pro
https://linustechtips.com/topic/925982-which-microphone-should-i-get-please-help/
@Swegly What are you using the mic for?
I'd highly advise against the floureon. It needs an interface in order to connect to your PC (not included).
Ease of use will go to the snowball. I personally have one, and would highly recommend it for a entry level audio recording device.
I want to upgrade the mic quality on my stream. Should I get a pop filter and boom arm for the snowball?
