Looking for Bluetooth & Wired combo headset
Hello!!
I currently own a HyperX Cloud 2 headset for almost 3 years now and I am getting tired of having to move the wire out of my way in most of my daily uses. I use it at home and bring it at the job also. Here is how I use it mostly:
Gaming/Chatting at home with the USB dongle
Plugged in my phone for music listening or phone call
Music listening at the job with using the Jack connector directly plugged in the computer (with a cable extender)
Here is what I would be looking for:
Main goal is to become wireless at home or with my cell phone
Use the wire for the job because no Bluetooth available
Around 250$ / 300$ CAD
I checked and tested the Steelseries Arctis 7 and the Lucidsound LS30 and they sound REALLY good and are in my price range, but they use a USB dongle and I really don't want to use this.   My goal is to either use Bluetooth or directly plugged into the motherboard (The dongle on my HyperX adds an annoying "white" noise that is noticeable on low volume content).
What do you guys think?  Is what I am looking for feasible?    would you recommend against my goal?
https://linustechtips.com/topic/925821-looking-for-bluetooth-wired-combo-headset/
So I found these while searching the internets:
https://www.plantronics.com/us/en/product/backbeat-pro-2
Any review from someone using them?   I'd be using them for gaming or music listening. I'm not looking for "7.1 surround" headsets, as long as it's stereo I'm fine with it.
With a modmic 5 if the microphone is not good enough for gaming.
