I'm making a custom computer case and need templates for hardware. I found a template for the SSD, but can't seem to dowlnoad it for some reason.   http://pdfsr.com/pdf/ssd-template-tested-exact-drill-holes the "verification" needed to download the file never comes up.
Anyway, if anybody can either help me download the file, or have any SSD/HDD templates, holla at me.
Any help appriciated.
https://linustechtips.com/topic/924985-ssd-template-help/
Put some painters tape on the bottom of the ssd.... take a sharpie, mark the holes, take the tape off and transfer it to where you cutting....
R7 5800x -:- Asus ROG Strix X570-F Gaming -:- EVGA FTW3 Ultra RTX3080 -:- EVGA 850 GA -:- 32GB G.Skill TridentZ Neo  -:- Asus TUF GT501
https://linustechtips.com/topic/924985-ssd-template-help/#findComment-11325328
Here's s set of dimension drawings to provide some more details.
https://linustechtips.com/topic/924985-ssd-template-help/#findComment-11327381
