Posted May 7, 2018 So, I setup openvpn on my vps, Forwarded all traffic through 433, But even at school it doesent work. School does not block 433, I set it up as tcp, Could that be blocked? Link to comment https://linustechtips.com/topic/924639-help-with-openvpn/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 7, 2018 I am pretty sure your school block the protocol and have DPI. I would look at Stunnel+Openvpn. Even then it might not work, as school network it usually run through a proxy which block certain services. The best way is to setup a web proxy on your VPS, you just have to change proxy address once awhile depending if your school blocks it eventually. I wouldn't share it, as more people use it, the most likely it will get blocked. Magical Pineapples
