I purchased a fiio e10 2 days back, worked fine for about 6 hours before I ran into two prominent issues. Either the AMP just stopped working along with the sound mixer freezing or I got a BSOD (Kernel_Security_Check_Fail).
I tried playing with the drivers, no luck. I thought maybe it was a usb issue so I swapped back and forth between 3.0 and 2.0, i even unplugged every other unneeded USB out of sheer curiosity; still no fix. Not a headphone issues because the headphones them self work perfectly fine without the AMP, but I would very much like to get the problem solved so I can utilize the higher quality sounds. If anyone has any idea of solutions, they'd be very much appreciated.
Headphones: beyerdynamic DT 770 PRO 250 Ohm
AMP: Fiio e10 USB&DAC
Specs:
Windows 8.1
i5 6500 3.2ghz
16gb ram
Gigabyte b150m-ds3h-cf(motherboard)
gtx 1060 6gb
Samsung SSD 850 EVO 500gb
https://linustechtips.com/topic/924634-fiio-e10-usbdac-problem/
