So I have the wall paper engine, if you don't know what it is, it's a program that allows you to have moving windows etc. So, my background detects the audio that is playing on your computer, and it makes the audio wavelengths i guess. So I'm wondering, since my volume is relatively low since I don't want to blow out my ear drums, if I can make the program like recognize/hear my system louder than it actually is. If you are familiar with the wall paper engine, or could help me, please do. Thanks in advance.
https://linustechtips.com/topic/924066-wallpaper-engine-w-audio/
So you want to decrease sound audio all audio from wallpaper engine specifically?
Desktop benching:
Just now, Jurrunio said:
So you want to decrease all audio from wallpaper engine specifically?
No, there is no audio coming from the wallpaper engine. I want to increase the audio that the wall paper engine recognizes I guess. It's kind of hard to explain, but like the wallpaper engine detects your system audio, but I want it to detect it louder than it actually is, if that makes sense.
If your output device allows for it, turn down the volume on it, but bump the volume on windows. Or if you can't do that, you can try tweaking the settings on the wallpaper itself (some of them let you) to increase the "audio effect". You can also try messing around with windows volume mixer, but chances are it won't help you depending on your specific output device.
print "Hello World!" ("Hello World!")
so you mean you want wallpaper engine to give out some noise? Ypu have to use a wallpaper with sound first.
Desktop benching:
