It'll just shut down lol
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/923921-no-load-on-psu-problems/#findComment-11313213
10 minutes ago, The321 said:
@JDE it's a old oem psu will it surely shut down ?
It's a basic protection so if it doesn't it's probably not safe to use
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/923921-no-load-on-psu-problems/#findComment-11313451
4 hours ago, The321 said:
Soo I heard that if u put no load on a psu and let it run it will kill itself. Why soo?
And how much load should than be the minimum ? And what rail ?
Very old PSUs had an issue with zero load.  But the PSU would not kill itself.  The voltages would be way out of spec and if they're way way way out of spec, the PSU would just shut down.
https://linustechtips.com/topic/923921-no-load-on-psu-problems/#findComment-11314055
