Just now, Niggapink said:
oh ok but if i installed 64 bit does it uninstall all my apps??
it will wipe the SSD/HDD. apply Win 10 64-bit. it will be a clean install of win 10. i am in the same boat as you. im re-doing my OS this summer as it is on my laptop
https://linustechtips.com/topic/923449-win-10-32bit-64-bit/#findComment-11308683
31 minutes ago, GoldenLag said:
not that i know of or have looked up. time to back up your data. also im pretty shure there isnt a way to go from Win 10 32 bit to 64 bit. im sorry
This. These are quite different architectures, only way to switch is via clean install.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
https://linustechtips.com/topic/923449-win-10-32bit-64-bit/#findComment-11308744
thats what i figured out after some digging aswell. i was an idiot when i did the install. and that was a year......
https://linustechtips.com/topic/923449-win-10-32bit-64-bit/#findComment-11308749
4 hours ago, Niggapink said:
is there a way that it wont wipe the data??
The installer detects if there's another Windows already installed. You can select to keep files. They can be found on Windows.old folder. You will still need to reinstall all software.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/923449-win-10-32bit-64-bit/#findComment-11309503
