So like, wat do?
This is something that started happening in the last month or so. I have an i7-6800k overclocked to 4.0ghz. I have 32gb of memory, and honestly not sure if it's the memory or my system in general but I don't think my memory has ever run as it should, any time I've ever ran the memory at its advertised 3000mhz it always had blue screen issues, me not sure if it's due to bad memory or just the way Broadwell-e cpus are, someone telling me it could be that.
Over a month ago I've looked up guides on how to properly overclock broadwell-e cpus, something that whenever I tried doing before it never turned out right. With the guides I was able to get my cpu up to 4.0ghz and even oc my cache a bit as well, that being something that if I so much as touched before I'd get blue screens. Things on the cpu side are stable, and the temps are great, so I'm pretty sure the issue isn't there.
At some point I ran into this blue screen, I looked it up and saw it was related to memory issues. Something said it could be related to an overclock. When I did my overclocking before I didn't set my memory at its full speed, I set it at 2800mhz. So when I got this issue I lowered it down to 2666. Things were working fine, no issues for a couple weeks until the other day, and again just now. After it happened just a bit ago I just decided fuck it, and removed the overclock for my memory, turning off the XMP profile and running it at the stock 2133mhz.
Any clues on what my issue is? Is it a memory problem or is it just overclocking on broadwell-e being a douchebag?
https://linustechtips.com/topic/922848-irql_not_less_or_equal/
Not sure if it is related to my overclock or not, that just being what someone mentioned it could be. I have run the whole microsoft memory diagnostic and it came back saying I was good. One method I've seen people mention is disabling memory caching but not sure if I want to try that or not
https://linustechtips.com/topic/922848-irql_not_less_or_equal/#findComment-11303156
Revert to stock settings and see if you can recreate the error. Also run Memtest86
https://linustechtips.com/topic/922848-irql_not_less_or_equal/#findComment-11303170
54 minutes ago, Inception9269 said:
So like, wat do?
Stop OCing until you determine the root cause of the issue (which is probably your OCing...)
And yeah, run MemTestx86 *overnight*, it'll tell you if your ram is good or not.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/922848-irql_not_less_or_equal/#findComment-11303304
1 hour ago, Ryujin2003 said:
What is your voltage and mem speed?
Whatever XMP sets it to. I removed the ram OC.
https://linustechtips.com/topic/922848-irql_not_less_or_equal/#findComment-11303406
Is that something I have to pay for or can I download it for free?
https://linustechtips.com/topic/922848-irql_not_less_or_equal/#findComment-11303408
