22 minutes ago, lambuibao said:
It's unavailable? Are there any pre-owned ones?
How much are you willing to spend? If you are willing to build one you can get exactly what you want.
Also you can post on r/mechmarket saying you looking to buy a white/blue themed TKL.
Also: https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=3617
and: https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=2275
or: https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=1877
or: https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=2676
or: https://pimpmykeyboard.com/all-products/keysets-kits/
https://linustechtips.com/topic/922836-help/#findComment-11303083
