So i recently discovered this problem on my gpu where it would overheat and the whole computer would restart this has not happened to me before but only when i played fortnite for the first time it pinned my gpu usage at 100% which was really wierd i was running on highest settings but this had not happened to me while playing pubg or similiar games i can run the game if my fan speed is set to 100% but with the auto fan curve it overheats and crashes my pc and i have the gigabyte 2 fan model
My case is thermaltake commander 2 with 2 exhaust and 2 intakes all 120mm good quality fans
And my cpu is 4690k not overclocked at the moment because of my gpu overheating
https://linustechtips.com/topic/922412-1060-overheating/
What are your temps you are seeing? GPU usage at 100% is what you want when you are playing games...
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/922412-1060-overheating/#findComment-11298679
Just now, Twist3relelelele said:
My pc just restarts and im not getting that high temp just under 80c which shouldnt be dangerous for the gpu
then thats not a GPU overheating if your temps are below 80c...Usually there is one main (though could be others) reason that a PC would just restart without any type of warning or BSOD, and its not from your GPU "overheating" when its clearly not at below 80c, its from a faulty power supply. What power supply do you have?
Community Standards
"Beast Mode"
https://linustechtips.com/topic/922412-1060-overheating/#findComment-11298691
I have got the vs450 but when i put the fan speed of the gpu to 100% the pc didnt restart anymore and it might be the psu aswell because its a pretty old one 4 years now but it does have enough power to run my computer i have stress tested this at 100%cpu and gpu load overnight when i got my 1060 and it was fully stable
https://linustechtips.com/topic/922412-1060-overheating/#findComment-11298698
