hello,
Eveything in my desktop pc is new except the case, which i bought used, altough that doesnt matter. Everything works, except this.
I can turn on my desktop with the power button, it lights up, everything good, but when im OC'ing and if in some cases everything freezes and i have to manually shut my pc down nothing happens. I hold the power button but nothing happnes, i can hold it for 5 seconds or 50, it just does nothing, but it will power up ? eveything else works for some reason. Any ideas?
Thanks for answers in advance.
https://linustechtips.com/topic/922138-holding-power-button-does-nothing/
3 minutes ago, hconverse02 said:
If you plugged it in wrong, it's the pwr + and pwr - or something similar to that.  Refer to your mobo manual to be sure, it's part of the front panel headers.
alright, thanks alot for the ultra fast reply :D
Can i do it while its on or do i have to power of the pc completly ?
Intel Core i7 4790K 4.8GHz | MSI Z97 Gaming 5 | 32GB 2133MHz CL7 DDR3 | nVidia GeForce GTX 1070 with Custom BIOS | Samsung 850 Evo 500GB | 3TB Seagate FireCuda SSHD | 2TB Seagate FireCuda SSHD | Corsair CX750M  | Custom 240mm all-in-one liquid cooler | Broadcom NetXTREME 5709c Dual Gigabit NIC | Cougar MX330 mid-tower chassis | Windows Server 2008 R2 Datacenter
