Hello.
I just finished building my new PC. I turned the PC on and there is nothing on the screen. Everything is working from inside and the GPUs led is working but the gpu fans were not spinnign. Any solution?
Build:
Ryzen 7 2700x
Asus Strix 1070 ti 8gb
16ram
650W
Ax370 k3
Thanks
https://linustechtips.com/topic/921888-display-problem/
Take out the GPU, plug video cables into the motherboard, boot into windows.
Download Geforce Expirence and display drivers for your card.
https://www.asus.com/us/Graphics-Cards/ROG-STRIX-GTX1070TI-A8G-GAMING/HelpDesk_Download/
Turn of the computer, Install the card, plug video cables into the card (NOT THE MOBO THIS TIME).
https://linustechtips.com/topic/921888-display-problem/#findComment-11293057
Nope not working ???
https://linustechtips.com/topic/921888-display-problem/#findComment-11293118
16 hours ago, JakeJigsaw said:
does the system work without the GPU installed?
It won't work without the GPU since the 2700X can't do display output without an iGPU.
I'm guessing that the GPU fans aren't spinning up because of the stock fan curve, I looked up your GPU and below 55C the fans won't fire up. Assuming everything in your PC is working fine, there has to be a problem with either the cable you're using or the monitor. Have you tried a different cable or different port (DisplayPort, HDMI, etc.)? Maybe try a different monitor too?
ʕ•ᴥ•ʔ
MacBook Pro 13" (2018) | ThinkPad x230 | iPad Air 2
https://linustechtips.com/topic/921888-display-problem/#findComment-11295271
Yep I changed 2 monitors, 2hdmi dvi and my friend said that i gotta upgrade the Bios. I will try that. If i get positive res ill post here.
Thank you for your advice.
https://linustechtips.com/topic/921888-display-problem/#findComment-11295598
