Ok so here's the thing I need some help with buying a computer chair and I decided to give the LTT forums a shot.
I need a high-back chair with plenty of should space, adjustable arm rests (both height and angle if possible), headrest and long as possible longevity to it.
I recently tried the DX racer medium sized chair at staples and I literally couldn't fit my shoulders in it, I'm built like a football player (never played, never cared) wide shoulders and I'm 6' 3" so finding a chair I can lean back into is kinda ridiculous at this point.
I'm currently looking at the DX racer OH/CS120/N/FT though anything cheaper would be preferable...
any suggestions would be appreciated.
https://linustechtips.com/topic/921093-need-help-with-chairs/
So I'm 195 cm or 6'4 and well let's say I can make a bright day dark while standing in front of someone =P
I got the AK Racing Premium one in black/brown and that fits nicely... only one thing I had to adjust to, the armrest are not coming up as high as I would have liked. else it is comfy for sitting upright, and comfy in reclining on foot up the desk... I really like it. But it was about 300 bucks (€).
here a Link to some pictures... in my view it is the top line:
https://www.google.com/search?q=AKRACING+Premium+V2+schwarz-braun&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwjll_v_-tnaAhUKblAKHQ0VCqcQsAQISA&biw=1559&bih=909
Main System:
Anghammarad : Asrock Taichi x570, AMD Ryzen 7 5800X @4900 MHz. 32 GB DDR4 3600, some NVME SSDs, Gainward Phoenix RTX 3070TI
System 2 "Igluna" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
System 3 "Inskah" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
On the Road: Acer Aspire 5 Model A515-51G-54FD, Intel Core i5 7200U, 8 GB DDR4 Ram, 120 GB SSD, 1 TB SSD, Intel CPU GFX and Nvidia MX 150, Full HD IPS display
Media System "Vio": Aorus Elite AX V2, Ryzen 7 5700X, 64 GB Ram DDR4 3200 Mushkin, 1 275 GB Crucial MX SSD, 1 tb Crucial MX500 SSD. IBM 5015 Megaraid, 4 Seagate Ironwolf 4TB HDD in raid 5, 4 WD RED 4 tb in another Raid 5, Gainward Phoenix GTX 1060
(Abit Fatal1ty FP9 IN SLI, C2Duo E8400, 6 GB Ram DDR2 800, far too less diskspace, Gainward Phantom 560 GTX broken need fixing)
Nostalgia: Amiga 1200, Tower Build, CPU/FPU/MMU 68EC020, 68030, 68882 @50 Mhz, 10 MByte ram (2 MB Chip, 8 MB Fast), Fast SCSI II, 2 CDRoms, 2 1 GB SCSI II IBM Harddrives, 512 MB Quantum Lightning HDD, self soldered Sync changer to attach VGA displays, WLAN
https://linustechtips.com/topic/921093-need-help-with-chairs/#findComment-11285614
I own the DX Racer classic and im like 6'0, You need to be carful at your height with that chair because you might find the built in headrest is more at the height of your shoulders which as you can imagine is not that comfortable,
Processor: Ryzen 5950x GPU: RTX 3080  Mobo: X570 Aorus Pro RAM: 32GB DDR4 3200Mhz CPU Cooler: Noctua NH-D15
https://linustechtips.com/topic/921093-need-help-with-chairs/#findComment-11285947
I am like you, and very broad shouldered.  I have the DX Racer Max, and find it uncomfortable, getting pain in my upper back and sometimes obliques after sitting in it for extended periods because it forces my shoulders forward.  I'm with @geo3 on this one, get a solid executive chair and thank yourself later.  I would not buy a DX Racer (or similar) again.
CPU: Intel Core i9 9900K GPU: Gigabyte AORUS GTX 1080Ti 11GB RAM: G.Skill Trident Z RGB 32GB (4 x 8GB) DDR4-3200 Motherboard: Gigabyte Z390 AORUS MASTER PSU: EVGA SuperNOVA G3 850W 80+ Gold Storage: Samsung 970 Pro 512GB M.2 / Samsung 860 Evo 2TB 2.5" CPU Cooler: Corsair H150i Pro Case: Lian Li Lancool One
https://linustechtips.com/topic/921093-need-help-with-chairs/#findComment-11287341
  • 2 weeks later...
