120 mm fan is makeing enormus amount noise
if i run it for a few minutes and restart pc
the noise stops is there anyway i could fix the fan
its new only a month old hardly
CPU: Fx 8350 | CPU Cooler: Coolermaster Hyper 212 Evo Now  AMD STOCK CPU COOLER | Motherboard: Gigabyte GA-970A-DS3 (rev 1.1)   NOW MSI 990FXA-GD80 | Ram: Corsair Vengence 8GB DDR3 Motherboard detects 7gb for some weird reason | Graphics Card: SAPPHIRE HD 7870 GHz Edition 2GB GDDR5 |  HDD: 1 TB samsung
Case: CM elite 310 | Monitor: Aoc e2050S
OS: Windows 8 Professional 64 Bit NOW  Wndows 10 Professional 64 Bit
 Power Supply: Cooler Master Thunder 500W NOW GX 650W v2
https://linustechtips.com/topic/92102-120-mm-fan/
What is the name of the fan?
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/92102-120-mm-fan/#findComment-1241336
there might be something wrong with your power supply
CPU: Intel Core i5-4670k Mobo: MSI Z97 Gaming 3 RAM: Crucial Ballistix Tactical Tracer 8GB 1866 Video Card: MSI GTX 970 GAMING 4G SSDSamsung 840 Evo 250GB HDD: WD 1TB + 500GB Caviar Blue
PSU: EVGA SuperNOVA 750W G2 Case: Gigabyte GZ-G1 Mouse: Corsair M65 RGB Keyboard: Corsair K70 MX Brown MousePad: Corsair MM200
Steam/Origin/Uplay: renz62
https://linustechtips.com/topic/92102-120-mm-fan/#findComment-1241374
Check BIOS hardware settings?
Big Bertha3570k @ 4.5GhzASRock Fatal1ty Z777970 DCUII TOP EVGA GTX 780Swiftech H220 w/ NF-F1216GB RAM128GB Kingston HyperX 3K1TB Western Digital Black40GB Western Digital Raptor 10K PeripheralsMionix 3200 MouseCMStorm Quickfire Rapid w/ Cherry MX Blues2 x Dell U2713HM AudioAsus ROG Orion Pro HeadsetSony XB-500AKG K240Bose AE2i​Fiio E10
Samsung Galaxy S45.0" 1920x1080p Super AMOLED screen16GB Storage2600 mAh battery1.9Ghz quad-core Krait CPU2GB RAMCyanogenMod CameraNikon D310018x55mm NIKKOR VR Lens14.2 MP
https://linustechtips.com/topic/92102-120-mm-fan/#findComment-1241381
How and where its connected? Does it run full rpms or sound like something is hitting it?
it runs at full fps  .
i checked its the fan
i cleaned dust off it
still it makes very loud noise when i start my pc after a couple of minutes fan does not make any noise
https://linustechtips.com/topic/92102-120-mm-fan/#findComment-1247236
Well all fans run full rpm on start. Thats how mobo checks that they are working. After that it applies fan controls to them so that they react either to temp changes or stay at some stable speeds. Thats is if they are connected to mobo and not straight to psu.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/92102-120-mm-fan/#findComment-1248403
