i'm having issues with a friend's usb drive. it is a really cheap 8GB drive.
i borrowed it because my laptop was having some problems and i wanted to reinstall ubuntu on it very quickly.
i plugged it in, tried to format it with gparted and got an input/output error. ever since, i haven't been able to format it. i either get an input/output error or a read only filesystem error.
i did try overwriting it with the dd command, but that gave me a really weird result. it only copies 5.4GB and then the drive according to gparted is 3.8GB in size instead of 8GB.
there is nothing important on the drive, and if i can't fix it i'll just buy a new one, but yeah.. it isn't mine so i'd like to be able to to give it back in working condition.
She/Her
Phone: OnePlus Nord CE 5G | 128GB | 8GB Ram
Main Desktop: Ryzen 5 3600 | GTX 1060 6GB | 32GB Ram
Main Laptop: Acer Aspire V3-771G | Core i7 3612QM | 16GB
https://linustechtips.com/topic/920326-usb-drive-issues/
I'd suggest trying SDFormatter. It fixes most of the drives I've come across with formatting issues.
https://www.sdcard.org/downloads/formatter_4/
EDIT: If none of them fix it, chances are the drive is dead. Not unexpected from cheapo USB drives
https://linustechtips.com/topic/920326-usb-drive-issues/#findComment-11278450
20 minutes ago, Pangea2017 said:
do have done a read to verrify the writing?
fake usb drives are real.
it was working fine before i plugged it into my laptop. i've seen it work on his laptop.
She/Her
https://linustechtips.com/topic/920326-usb-drive-issues/#findComment-11278521
