QLED DRAM Error (Q-Code LED C0)
RAM => G.Skill TridentZ RGB 16 GB (F4-3600C15D-16GTZ)
Motherboard => ASUS Crosshair VI Hero Wi-Fi (X370)
CPU => Zen+ 2700
Thank you so much Fabio!
I found what was the problem:
-the mother couldn't boot because couldn't read the RAM memory [ QLED DRAM (yellow) with error code ( C0 ) ], so i needed to update the bios,
but the BIOS couldn't be update because it fails.
It fails because the Asus User Manual is WRONG!!!
if you have the Wifi version of ASUS Crosshair VI Hero you HAVE TO NAME THE ROM like: C6HWIFI.CAP
After 6 tries, the last one with the right name works like a charm!
Now all is working good and smooth!
Thank you again Fabio! This post helped me to find a north in the darkest hours late night! Hope this helps to everyone who have the same problem!
Greettings from Argentina! ![]()
EDIT: Now i see i was post it on Asus forum as well
Source: https://rog.asus.com/forum/showthread.php?97223-Crosshair-vi-hero-wi-fi-ac-Usb-bios-flashback-fix
