Need Opinions.
Go to solution Solved by Froody129,
3 has no white (well it does but not like a Portal theme) and I can't deal with the uneven colour distribution on 2, so I like 1 the best
Hi,
i am currently planning on my Portal themed pc and i'm currently deciding on what the  PSU cables should be. I have attached some images below on what are my top 3 choices but can't decide on which one to go for.  Its going to be going in a white s340 Elite.
Which one do you think i should pick?
image.png.f83f1292fbe39479112bc777a384eb41.pngimage.png.231c1a8d0ec40302beeaf5ae60a2f14a.pngimage.png.6c6a4ebe1f85f5dfd8ae85c3650424a9.png
https://linustechtips.com/topic/919323-need-opinions/
First one is the best imo
REMEMBER:
IF YOU WANT ME TO RESPOND, YOU GOTTA QUOTE ME
OR
PUT @Fixinit1 IN YOUR RESPONSE!!!!!
Gosh, I hate it when people forget. Anyway, check out my PC below, and there's a PCPartPicker link on my profile, If you wanna see what I'm planning.
SYSTEM SPECS: Finally ditched the Pentium N3540, now I've got the following:
CPU - Ryzen 5 2400G
GPU - 1060 6GB Gigabyte G1 Gaming
RAM - 16GB DDR4 3000mhz Team T-Force Delta RGB
MOTHERBOARD - MSI B350 Tomahawk
PSU - EVGA 450BT
CASE - PHANTEKS  P350X
https://linustechtips.com/topic/919323-need-opinions/#findComment-11268790
I'd say first one.
CPU: Ryzen 7 1700 @3.85Ghz, MotherBoard: Asus ROG Strix X370-F, RAM: G.SKILL TridentZ RGB Series 16GB 3000Mhz
GPU: GALAX GeForce® GTX 1080 Ti EXOC White, Case: NZXT S340 Elite Matte White, Storage: Samsung SSD 850 EVO 500GB, PSU: Corsair CX650M
https://linustechtips.com/topic/919323-need-opinions/#findComment-11268793
very patriotic
PC Build: R5-1600.  Scythe Mugen 5.  GTX 1060.  120 GB SSD.  1 TB HDD.  FDD Mini C.  8 GB RAM (3000 MHz).  Be Quiet Pure Wings 2.  Capstone-550.  Deepcool 350 RGB.
Peripherals: Qisan Magicforce (80%) w/ Gateron Blues.  Razer Naga Chroma.  Lenovo 24" 1440p IPS.  PS4 Controller.
Audio: Focusrite (Solo, 2nd), SM57, Triton Fethead, AKG c214, Sennheiser HD598's, ATH-M50x, AKG K240, Novation Launchkey
Wishlist: MP S-87, iPad, Yamaha HS5's, more storage
https://linustechtips.com/topic/919323-need-opinions/#findComment-11268801
I Guess i will go with one. Don't think my OCD could take it if i went with two. 1 seems to have the most votes.
https://linustechtips.com/topic/919323-need-opinions/#findComment-11268889
