Why is 30fps in console better than 30fps on PC?
Go to solution Solved by Frankenburger,
It's because console games can be optimized exclusively for a specific set of hardware. There are no unknown variables, which allows developers much greater ease at optimizing frame times, which is perhaps more important than frame rate. Developers don't get that kind of luxury when optimizing for PC, since PC's can come in thousands of possible different hardware configurations, let alone hundreds of thousands of software configurations.
Or get g-sync monitor and all problems will be gone away with stuttering and etc thingies.
In general, console developers don't just aim for 30fps, but also a consistent 33.33ms render time, which results in smooth, albeit slow, presentation.  Because of sheer diversity of configurations among the PC player base,  aiming for a smooth frame time isn't quite as simple, so developers simply include half-refresh V-sync as an option in the settings.
CPU -AMD R5 2600X @ 4.15 GHz / RAM - 2x8Gb GSkill Ripjaws 3000 MHz/ MB- Asus Crosshair VII Hero X470/  GPU- MSI Gaming X GTX 1080/ CPU Cooler - Be Quiet! Dark Rock 3/ PSU - Seasonic G-series 550W/ Case - NZXT H440 (Black/Red)/ SSD - Crucial MX300 500GB/ Storage - WD Caviar Blue 1TB/ Keyboard - Corsair Vengeance K70 w/ Red switches/ Mouse - Logitech g900/ Display - 27" Benq GW2765 1440p display/ Audio - Sennheiser HD 558 and Logitech z323 speakers
