Remove the wooden wall skirting, put the cable behind it, re-apply the wall skirting.
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
https://linustechtips.com/topic/917683-hiding-ethernet-cable/#findComment-11252714
This ^^^^
Although the easier option would be to buy a couple Powerline adapters and not deal with the long cord at all. Using those would also be less permanent than tearing out the trim and everything.
https://linustechtips.com/topic/917683-hiding-ethernet-cable/#findComment-11252718
Seems like a good idea but if the situation is as the pic shows, it also means removing the trim not only from the floor, but also around the doors.  Cable may provide better service in this situation but if he is looking for ease of installment, go with the power line adapters.
https://linustechtips.com/topic/917683-hiding-ethernet-cable/#findComment-11252738
5 hours ago, Brian Blankenship said:
was just gonna say that.
But there is no baseboard where the door is in the middle that they need to traverse to get from one side of the hall to the other.
For this I'd have to agree with previous posts and recommend the Powerline adapter; or MoCA adapters if both rooms have COAX TV that are connected.
https://linustechtips.com/topic/917683-hiding-ethernet-cable/#findComment-11257168
Whenever I need to do that I just go up and around the door frame. If it is too visible, just paint it to match the wall.
https://linustechtips.com/topic/917683-hiding-ethernet-cable/#findComment-11264111
